unconfigure stacking
unconfigure stacking {node-address node_address | slot slot_number}
Description
This command resets most stacking parameters to the default or unconfigured values.
Syntax Description
node_address
Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command.
slot_number
Specifies the slot number of the target node. To view the slot numbers, enter the show stacking command.
Default
N/A.
Usage Guidelines
Run this command from any node. If you do not specify a target node, the stacking parameters on all nodes are reset.
This command resets the stacking parameters shown in the following table.
Table 1. Stacking Configuration Items, Time of Effect and Default Value
Configuration Item Takes Effect Default Value
Stacking Mode
At boot time
Disabled
Slot Number
At boot time
1
Master-Capable
At boot time
Yes
License Restriction
At boot time
Not Configured
Priority
At next master election
Automatic
Alternate IP Address
Immediately
Not Configured
Stack MAC
At boot time
Not Configured
This command does not reset the stacking parameters configured with the following commands that use the stacking-support keyword:
To unconfigure the stacking parameters of all nodes in the stack topology:
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.1.1 Licensing Guide document.
